Some help guys!
Whats best for a buggy to run on?
I.e.. Short grass? Gravel ect?
The buggy I have is this - http://www.********.co.uk/proddetail...169c78cf1eb2e5
I used to have a Thunder Tiger DT10 stadium truck, which made easy work of most things as long as they wern't any bigger than a building brick...
So what would you guys suggest for me to look out? Empty short grass fields? Gravel car parks?
And how can I tell if my buggy is using second gear? Is it automatic without a shift? Or should I notice a drop in revs? And then an increase?
Cheers for any responce's!
Jack
Jack
CA
It should work great in short grass, gravel, or dirt.
As far as the shift as it reaches high rpm you should notice a lunge or a small drop in rpm as it keeps pulling.
Hope this helps, nice looking buggy...
Cheers dude. Much appreciated.
Took it out today now it's broken in and WOAH!
This thing is real good! On long stretches you could see the second gear/ratio kicking in as it hit higher rpm's and flew!
Real good buggy, only problem was the throttle/brake servo needed a longer arm on it, to fully open the throttle!
Easy done though!
Easy done though!
