Need Help ID'ing a motor
Old 01-13-2005 | 08:15 PM
Default Need Help ID'ing a motor
Anyone have any info on this motor or know how I can tell how many turns it is?
Old 01-13-2005 | 08:17 PM
aliens8mycow's Avatar
Default RE: Need Help ID'ing a motor
Your best bet would be to pull the armature out and see if it's stamped on the wings.
Old 01-13-2005 | 08:51 PM
I just tried pulling the arm, motor won't come apart. There are tabs bent in on the sides and I can't pry them up to get the endbell off.
Old 01-14-2005 | 09:52 AM
did u try taking it to a hobby shop to see if they can help??
Old 01-14-2005 | 02:50 PM
i havent seen one of thouse in a long time. i cant rember how many turns, but it is/was a realy good buggy motor.
Old 01-14-2005 | 03:57 PM
i have one somewhere around here that is like it in i belive it was a 20 turn or 23 turn
Old 01-14-2005 | 04:19 PM
I was guessing above 14t and basically around a 20t by the ohm-meter readings I took. I figured that might get me close at least. Read pretty close to my 19t race prep.
Old 01-14-2005 | 04:26 PM
aqua_al's Avatar
i'll gess 21 seen one like it to a race some time back,
but im not sure.
Old 01-14-2005 | 07:29 PM
That is a stock motor. It's the Losi version of the Slot Machine 2. It's 27 turns.
Old 01-14-2005 | 08:12 PM
well, i've heard anywhere from 19 to 27t. Thought it would be easier than this!
On the 27t ones, did they use larger wire? It doesn't ohm read anywhere near any of the 27t motors I have, it ohms closer to a 20t than anything.
Old 01-14-2005 | 08:52 PM
i8tweety's Avatar
It most certainly is a 27 turn stock motor.
Old 01-15-2005 | 05:30 AM
xtremraptor's Avatar
My Feedback: (24)
look thru that hole in the side of the motor and turn the motor till you see a stamped # on the side of the armature. that should be the turn
