Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Car General Discussions
 starting a dxt 18 problems  it want start >
Old 01-23-2005 | 01:48 PM
Default starting a dxt 18 problems it want start
[:@]aight i got a dtx 18 for a dura traX buggy bx .. i ran about a gallon of fuel 20% traxxes fuel threw it and one day i tryed to crank it and it will not crank . i tore the hole motor down 2 times and it want hit at all i . i got new glow plugs and their hot . and a good starter and i just pull and pull and pull nothing happens .high speed is 2 turn out low speed is flush with housing . nd my room is 70 degrees . so if any body can help me thanks [:@][:@][:@][:@]
Old 01-23-2005 | 03:53 PM
Default RE: starting a dxt 18 problems it want start
is it getting any compression? if it doesnt sound like it then try taking the air filter off and put ur finger over the hole, that works for me.
Old 01-23-2005 | 09:16 PM
Nitro Rustler Racer's Avatar
i see whats happening, ok, when you are about to start open full throttle and prime it, then leave it full throttle and start it, it should fire, when it starts just let of the gas, if this doesnt work then somthing is round with your engine annd you need to contects duratax
Old 01-24-2005 | 12:51 AM
well its getting fuel , but its kinda easy to pull . i filled up the cylender with 50 wt shock oil it got harder to pull . then i got ready i primed it and it cranked for like 5 seconds . after the oil left the motor it will not crank . is that a compression problems . and i need a new sleave and piston ?????????????????????
