Best way to remove spring pins
OH
What's the best way to go about it, should I just grip onto it with some pliers and pull away, or is there a trick to getting them off any easier?
KY
RE: Best way to remove spring pins
if they are broken, then it doesn't matter how you remove them as long as you dont damage the parts they are in. but if they are still usable, a pair of needle nose pliers works well, just dont squeeze too hard on the pin. use a twisting motion back and forth and it should come out fairly easy. or you could find a pin or nail and push the spring pin out from the other side.
