Question on Tuning (Jato)
Old 08-14-2005 | 09:53 PM
Default Question on Tuning (Jato)
I have a Jato with the stock 2.5 motor. I have the M/S airfilter and i'm running 33% Traxxas fuel.
When going WOT the motor will want to cut out. Sometimes it will. I check the temp during runs and the temp is about 200. I turned to richen the HSN 1 full turn and it runs fine at WOT but the temps drop to 170. I then start to lean it out and it runs fine but it won't go over 200. I even let the motor run for 2 minutes without driving and the temp went from 199 to 194. I know i can get more power out of this motor because i've seen it. Plus it wont shift to 2nd either.
