Need a bigger fuel tank for my Losi XXX NT
Hi, I'm new to this forum. I just bought a Team Losi XXX NT RTR truck and I'm looking for a bigge fuel tank, something bigger than the 75CC tank that it has now.
Does anyone know of another tank that would fit? or make it fit?
thanks!
Jason
FL
RE: Need a bigger fuel tank for my Losi XXX NT
welcome
there isnt a bigger tank for a xxx-nt and i have never seen one that would fit.....
alot of pepole say that its not good to have a bigger tank becuse then your engine could over heat due to longer run time....
Hmm..I see...well, I got a good run tonite on some dry ground. We have snow here, so its pretty icy..and 2WD doenst help!!..laugh
What all have you done to your truck? Big improvements?
Jason
Anymore other XXX nT owners out there?
FL
theres a ton of xxx-nt owners on here....
i have a fantom .15, robsion racing diff gear, titanuim turnbuckels, grafite all around, rpm bumper, threaded shocks,cvd's, metal gear servos, a set of road rage 2.2's a set of proline dirt hawgs, a set of proline gator grip's, and a set of losi pins..... there more but cant think of them lol
FL
oh yeah amd a mip stinger exhuast
look at this thread its a good source for info on your xxx-nt
http://www.rcuniverse.com/forum/m_81..._1/key_/tm.htm
FL
my top speed i got with mine was 44mph with a 20 tooth clutch bell and off road tires the actually lifted the rear of the truck up at a speed of 35 and up becuse they ballon so much
i havent used my vsm since i got my onroad tires
My Feedback: (29)
IA
losi xxx-ntkid: I noticed in one of your pictures it appears that the battery is above the steering servo. Is that an effort to keep the front on the ground, or what? I am new to this as well and I have trouble getting my NT to turn, while accelerating. It seems the front end is very light= won't turn.
Ron
Ron
FL
i just put it there to see if it would help but i didnt see that much improvement.... mine does the same thing change your suspension set-up so a softer than stock in the front so maybe it will grab and stiffer in the rear
I got a differnt exhaust in my box ( i bought it used), does it make a huge difference if i put a different exhaust on?
And whats a good mod? I believe mine is bone stock, its pretty quick so far..but havent tried any jumps or ramps...waiting for summer. or spring..
thanks for the advice guys
Jason
Jason
FL
the first two pics was a pipe off of my nxt becuse i bent the stinger on my stock pipe the stock pipe says "TL"(team losi) in a circle it should be in silver letters
the third pic was my mip 360 stinger exhaust system
what color is ur pipe?
can you post a pic?
can you post a pic?
FL
also what engine do you have?
if its stock it should be a mach .15 with a blue cooling head(if its the old xxx-nt)
the xxx-nt2 has a mach .15 with a black cooling head and rear exhaust
i have an old losi xxx electric car that is over 20 years old i dont no the full name but it worked well before i used the electronics on my buggie.
FL
ORIGINAL: c-crum
I think mine is a black cooling head, with the side exhaust tho...says team losi on it. And mine is the Mach .15
I should try and get some pics
It goes pretty good..but I have yet to find top speed. Need traction..
Raised my rear end today..seems like the truck sat pretty low in the rear...i might rasie the front a bit too..see how that works.
How much time do you get out of 1 tank of gas?
I broke one of my rear hubs yesterday..plastic shiat...i was looking on ebay at some of those aluminum hubs...would they be better? How about those aluminum arms? or should I just stick with the plastic ones.. i just want them to last..and not break too often. i dont really care for lightness or anything..this thing has power!!!
FL
ok if you have the black cooling head you have a xxx-nt2 which is better imho
i wouldn't get aluminum a-arms just because they are too expensive and they bend easy get a couple spare a-arms front and rear your going to need them....
you can get the aluminum knuckles i would suggest getting a name brand like dynamite
FL
ORIGINAL: playboyz28
10 mins!! thats crazy!....
ORIGINAL: losixxx-nt
welcome
welcome
Never had any overheating probs
FL
ORIGINAL: J_D
i dunno about that one mate, I run nitros in the heat of summer here, and usually go thru 4 tanks before i shut it off. Just come in, pull open the fuel cap squirt in more feul, and its off again.
welcome
welcome
ME
lol i know i'm in the wrong room here i'm an associated guy, but i have some good info for you losi guys the new xxxnt ad2 comes with a 125cc tank with a displacement block that you can put in or take out. when its in your legal 75cc and out 125cc for club racing or bashing. As far as the engine temps go with bigger tank if its tuned right it shouldn't bother we run 45 minutes mains and temps stay the same from the start of race to the end hope this helps
