Newbie to Nitro needs Help :)
Hi Guys,
Good news! I finally recieved my HPI Nitro MT back from the Hobbyshop with a New Pullstart installed and tuned.. BUT....
I still need help
I have now been able to start the car *Yay-New-Break-Through* but Im not exactly sure how the car is mean't to act when started. Let me explain...
1) I have noticed that I when I start my car and attempt to accelerate that the engine makes a *deep muffled noise* and the wheels don't spin. If I then turn the tuner on the engine to allow less air and more fuel then the car's wheel's will begin to spin automatically and the car begin's to rev quiet high. *** But Im scared that if I put the car on the ground, it will take off. So I alway's cut the engine cause Im scared it's ganna blow
1A) Any suggestions or TIPS? Am I being to careful or am I doing something wrong?
2) When it's started the engine is not to noisey.. I mean it isn't exactly quiet, but it's not "LOUD" - By closing the engine tuner the car starts to rev a lot higher and becomes much more noisey - is this how it should be?
Any help would be very much appreciated
Thanks in advance.
JoshB.
I still need help
Thanks in advance.
JoshB.
Drop it on the ground and see what happens.
You'll never know til ya try.
Sounds like your a little rich to me,But if your lean it'll do the same thing.
Does it idle?
When I get my cars going and the lean them out they run great.
Then the next day I have to go rich to get it started.
Then lean it out a bit.
It's all in the tuning.
BNZ'
BNZ'
Does it idle?
BNZ'
BNZ'
My Feedback: (16)
Check out the links for additional help.
http://teamrcv.com/article.php?sid=34
http://teamrcv.com/article.php?sid=49
http://teamrcv.com/article.php?sid=48
Good Luck!
Good Luck!
