HOW DO U MAKE HEADLIGHTS FOR 1/10th SCALE CAR
CA
I am new to rc but i want to put some headlights on my rc (its an old HPI sport i got from my brother) I have no idea what lights to use, what battery to use adn stuff like that so please help me.
RE: HOW DO U MAKE HEADLIGHTS FOR 1/10th SCALE CAR
use some LED's and power them with a 9V PPV battery
you have to put a resistor in seies with the LED's to ensure that you dont burn them out. LED's are diodes and have to be connected the right way round. the long leg goes to the positive terminal on the battery (thats the side with the + on)
the battery can be stuck on with sticky tape and that way it's easy to remove and change when it goes dead
WI
also, check out rcneon.com, they have light kits of all kinds. cool site. some hobby stores carry the light kits too.
CA
thanks for the help but which type of led is the brightest (i have seen like 300 somthing and 200 somthing) i also don't have much room for a battery, the only place would be like und the drive balt, here is a pic of my rc car
CA
500mw is a nice bright LED, you can tape the battery to the body, or shoegoo a 9v battery holder to the battery, that way the battery just clamps in the holder. Hyper Lighting on ebay sells a good selection of quality light kits.
CA
sorry about that pic only shows motor heres a better one and by the way how do you wire in parrellel
thanks for helping me
My Feedback: (16)
CA
Here ya go:
http://swami-rc.com/lighting.htm
http://inadad.com/led.shtml
What part of California are you in?
CA
CA
Thanks for all the help
those sites should help alot and by the way would you know what gets rid of spray paint (heard it was oven cleaner)
CA
Depends on how much paint you need to remove, Ive done it when some paint bled through the masks and got on the windows. I just let it sit for maybe 10 sec.
CA
i am trying to remove a paint job my brother did a few years ago (he painted the windows yellow)
CA
It may be too late to do that. If you messed up by quite a bit its best to just start over, theres no way of removing 100% of the paint. It works for small jobs but you have to react fairly quick.
CA
oh well guess i will have to stick with the dark yellow windows but what the heck thanks again
AB, CANADA
you guys seem to know what you are talking about with respect to leds. I installed an led system in my MT but i only had a 12v switch and it is a 9v system and the 9v battery would get hot and lose power within 15 mins, only running 6 leds. is this becasue of my switch?
I have only ever installed leds on 12v cars before, never worked with 9v
Any input is appreciated
CA
You may want to try a different switch, check all connectors and make sure they arent reversed or anything. Do you have a resistor on all of your LED's, if not you will want to do that.
CA
how many leds per headlight
led led 4Xled 4Xled
|_________| or like |__________|
o__O o__O
|9v| |9v|
|__| |__|
led led 4Xled 4Xled
o__O o__O
|9v| |9v|
|__| |__|
AB, CANADA
i had some hyperLEDs left over from doing up a fiberglass sub box for a buddy and they come with resistors pre soldered on. I was just wondering if the 12v switch was doing it, and if so where can i get a 9v switch>?
