engine swap
Old 04-12-2006 | 11:06 PM
Default engine swap
I have a duratrax buggy but the engine is shot and i was wondering is it possible if i drill new holes if needed to use a traxxas .15 high performance engine on mine. The engine looks like this http://www2.towerhobbies.com/cgi-bin...&I=LXJL58&P=PU
Give me some advice what you think of this engine thanks alot
Josh
Old 04-12-2006 | 11:26 PM
Wide Open's Avatar
Default RE: engine swap
thats their older engine, from my experience they havent been very reliable. personally i would recamend an o.s. they are very reliable, put out good power, and last a long time.
Old 04-13-2006 | 08:24 AM
ryan_t888's Avatar
I bet this O.S. engine has a pit more punch than that old Traxxas engine. http://www2.towerhobbies.com/cgi-bin...?&I=LXXA44&P=7
Price is alright for this decent engine. What do you think?
Ryan
Old 04-13-2006 | 09:02 AM
for the same price you can put the .18 in
Old 04-13-2006 | 09:33 AM
ryan_t888's Avatar
.... even cheaper, and more hp but less RPM's
Ryan
Old 04-13-2006 | 04:26 PM
so in other words it is possible to take any engine and put it into my car as long as the holes are drilled in the right spot. And can i just take the clutch bell and all that off and put it right onto another engine and it will go. get back asap thanks.
Josh
Old 04-13-2006 | 04:32 PM
ryan_t888's Avatar
There are three different crankshaft types. They include SG, threaded short shaft and threaded long shaft. If you find an engine with the correct type of crank you can swap over your current setup. Remember O.S. makes the same engine with the option of the 3 crank types.
Ryan
