Running engine temp
Old 04-17-2006 | 12:57 PM
Default Running engine temp
I run HPI 15FE engine on HPI MT truck and was wondering the normal running temperature in normal conditions. Assuming air temp 65 to 80 F and humidity 50 to 70%. It seems that my engine runs to hot in those conditions yet running it rich causes it to shut down at higher RPM. The temp I get is between 340 to 365 F sometimes reaching 390F in my normal settings and produces light blue smoke during acceleration and almost clear smoke during idle. Any ideas?
Old 04-18-2006 | 06:47 PM
Default RE: Running engine temp
Right first things firse.. what fuel are you using ? what glowplug are you using.
Right my first thought is basicially are you using a clean air filter? if you are not you may need to clean it. i do this by pouring nitro fuel over it then letting it dry then adding a light coat of filter oil...
secondly have u checked your fuel line for any air leaks and also check the engine case and carburetta seals if they are leaking this may be the problem. also the HEAD SCREWS , that will defineatly cause problems if they are loose..
nitro boost ...
