starter HELP
Old 05-04-2006 | 02:18 PM
pythonfan's Avatar
Default starter HELP
Can u start a motor with a pull start on a starter box after the pull start has broke.
Old 05-04-2006 | 02:44 PM
Wisconsin Nitro's Avatar
Default RE: starter HELP
yeah
you have to take the one way bearing of the pull start though or you can go buy a back plate for it and remove the pull start all together
Old 05-04-2006 | 03:23 PM
Sometimes you need lower engine mounts, because pullstart engines sit higher and the flywheel doesn't sit below the chassis cutout.
Usually you need a backplate and different engine mounts.
Old 05-06-2006 | 10:43 PM
ryan_t888's Avatar
As long as the starter donut contacts the flywheel and it is spun in the right direction it will work! No need to tear anything apart.
Ryan
