Help Rewiring Starter box!
Hey,
My mate has this problem. He has a Team magic X5 starter box with Corally connectors and wants to convert them to Tamiya connectors so he can use his stick packs. He has purchased 2 Tamiya connectors and Is unsure on how to wire these up!
There are only 2 wires coming out of the starter box with Corally conectors (Black and red) What dies he need to do to add Tamiya connectors to these so he can use 2 stick packs?
He drew this little diagram.
As you can see there are 2 wires coming out of the Starer box (Left hand side)! What dies he do to make this take 2 stick packs?
Thank you
Thank you
ORIGINAL: Momin
Hey,
Thank you
Hey,
Thank you
FL
He probalb yneeds to soder another wire to each of the electrodes (thats a total of 4 wires two negative 2 positive, and then hook them up to the tamyia connectors.
ORIGINAL: Dawman
All you need to do is hook each black wire from the new connectors to the one black wire on the box . Also the same for the red wiring .
He would like to use 2? Would we need to do what you said, and get some connector or something?
Cheers!
My Feedback: (33)
no , you have to use two . Actually I told you the wrong way . It would only get 7 volts that way . Cut the old plugs off the box , on one new connector connect the red to red wire onthe box . Connect that black wire on the new plug to the red wire on the other new plug and connect the remaining black wire on the plug to the black wire on the box . This way you will be giving the proper voltage to the box . Better yet , just get a gell cell from your LHS . Or a hobby supplier .
ORIGINAL: Dawman
I sort of understand what you are trying to say but still need a bit of help!
Do you mind drawing me a diagram on MS paint please? Like i did?
I am a newbie to these electrical stuff and really need advice!
Ive spent $55 on battaries for this! (Venom 3600MAH)
My Feedback: (33)
It would have been better and cheaper to buy a gell cell that is designed for starter boxes . Some reason it won`t let me upload my drawing . All you are doing is wiring the batteries in series . 2 stick packs will not last as long if you buy a gell cell .
Ok, is this what you mean?
Would i be able to Convert the starter box wire to a tamiya connector, Plug in a Tamiya connector Y harness and use 2 batterys?
Useing this?
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXD181
Useing this?
ORIGINAL: Momin
That is not like the picture you drew. It would only give you the same voltage, and twice the capacity. (parallel wiring)
This one has 4.5Ah, most likely much higher than the battery you plan on using.
http://www2.towerhobbies.com/cgi-bin...?&I=LXSK07&P=7
Ryan
Thanks for the replys guys, But what charger would he require to charge a Gel cell if he takes this route?
Cheers!
Cheers!
