RIT Dye
Old 08-01-2006 | 03:28 PM
BAMF90's Avatar
Default RIT Dye
Can I buy RIT Dye at Walmart. If not, then where can I get it?
Old 08-01-2006 | 03:36 PM
Default RE: RIT Dye
wal-mart should have it.
Old 08-01-2006 | 03:52 PM
BAMF90's Avatar
Default RE: RIT Dye
Ok, thanks. I'll try to get some tonight.
Old 08-01-2006 | 06:48 PM
Neil E's Avatar
Default RE: RIT Dye
I have seen it in the grocery store as well. If you are planning to dye plastic. Heat the solution to about 190 degrees F. Then put your parts in the bath. The dye will go deeper in to the plastic or nylon. Make sure you wash the parts real well. Use a good degreaser. Do not touch the parts after cleaning with your bare handes. The oil from you hands will leave marks. If this is stuff you already know, sorry for the repeat.
Old 08-01-2006 | 07:33 PM
BAMF90's Avatar
Default RE: RIT Dye
Thanks Neil. That is good information to know. I am actually trying to dye my Revo's rims.
Old 08-01-2006 | 08:12 PM
*Nitstklr72*'s Avatar
Default RE: RIT Dye
cool this help me so much im going to dye some mini t rims blue can i dye graphite if its silver
Old 08-01-2006 | 10:04 PM
mkincy's Avatar
Default RE: RIT Dye
graphite wont dye.
Old 08-01-2006 | 10:38 PM
Default RE: RIT Dye
Good information, but how long do you leave the parts in the dye?
Old 08-02-2006 | 12:03 AM
Default RE: RIT Dye
will can i get blue graphite
Old 08-02-2006 | 08:51 AM
BAMF90's Avatar
Default RE: RIT Dye
It depends how dark you want them to turn out. Very dark=let them soak a long time. Light=let them soak less.
Old 08-04-2006 | 03:45 PM
Neil E's Avatar
Default RE: RIT Dye
ORIGINAL: paul29
As long as required. I put a hook in the end of a coat hanger slide the part on the hanger and put in dye. Do not put more than one part per hanger. Parts will not dye where they touch. Pull them out after a while and check the color, as often as needed. I rinse the parts with cold water when done so the dye does not streak or get all over everything. It can get real messy if you are not careful.
