tempterure test?
Old 09-09-2006 | 01:17 PM
Default tempterure test?
right at the moment i dont have the money to buy a new temp meter to replace my old one so i was woundering if there is a simple way to give a rough indication of engine temp, i'm gussing someone should know as digital temp meters hadnt really been widly used up till a few years ago, i remeber somthing about puting a little bit of water on the head and timing how long it took to go
any help will be much appricated
Old 09-09-2006 | 06:39 PM
Default RE: tempterure test?
Spit on the head. If it sizzles and boils off almost immediately, like 1-2 secs or less, it is probably too hot. If it takes 3+ secs, you are probably ok. If it instantly vaporizes, you are way way way too hot.
Now, let me introduce you to other RC-ers who will tell you to not worry about temps. Just get the engine running perfect, then richen it slightly, make sure it sounds and looks/feels right, and forget about it. That, along with airflow past the engine, should be all you need.
