breaking in gx-12 engine
Old 10-07-2006 | 11:27 AM
Default breaking in gx-12 engine
Hi how do you break in and tune a kyosho gx-12 engine? also im looking to upgrade the engine next year, what would be a good upgrade.
thanks
Deano
Old 10-07-2006 | 12:52 PM
Default RE: breaking in gx-12 engine
do you have the alpha pure ten?
the best way to break it in is either with the heatcycle method or by idling through about 5 tanks.
Old 10-07-2006 | 03:45 PM
snowbl!nd's Avatar
Unless you're after a paperweight, use the heat cycle method. Idling doesn't do anything and is very bad for an engine.
Old 10-07-2006 | 06:15 PM
i have a kyosho pureten alpha, what is the heat cycle method?
Old 10-07-2006 | 06:52 PM
Try doing a search. The author would be by fuelman read what he has to say as he has a ton of knowledge about things like this. There is a good bit of reading to do though so be prepared for that.
Old 10-07-2006 | 07:26 PM
Thanks i searched for him and found the post i see what you mean about a ton of reading
