whats the diference between these servos ( help problem with the servos turns backwords)
NY
I got this spektrum DX3 DSM 3CH PISTOL and it brings 2 servos
# Z270 Standard Race Servo
# Z590 Hi-Torque Race Servo
what are the diference? which one can i use for steering? or are they both for the break/accelerate ?
VA
RE: whats the diference between race servo and high torque?
The 590 can be used for steering. I did for a while and it works but it's not the best. I use it for throttle now.
The 270 is weak but works for throttle duty. I used to use it but tossed it.
MI
There are many choices.
If you're putting it in a 1/10, you want 100 oz/in or more of torque and .15 or better speed.
1/8 buggies and monster trucks need more. 150 oz torque and .15 or better speed is good.
NY
im having problems with it though for my car when i presss the break/acelerator it turns the other one let me rephrase ( sorry my main language is spanish ) my old servo and controller works fine right but when i use the new ones it turns backwords in my old controller its easy to change but in the spektrum sicne is digital no idea i been reading the manual but not sure the name of that function any ideas?
RE: whats the diference between these servos ( help problem with the servos turns backwords)
The function is called a reverse switch. Just find that in the manual the instructions for reversing the servos. On the controller, the switch will be marked "rev." or "rev. switch" or "servo rev." etc. I don't own a Spektrum DX3 so I am not sure how it is exactly marked on your radio. Hope this helps.
GA
Turn on your DX3 and push the mode button 5 times then push the channel button till the servo you want to reverse comes up on the display.
