Can any one help me with my RS4 3 evo?
hi, i have got a very big problem, my cars gears keep stripping and i do not know what the problem is. I just bought a set of gears and on the first day they where already striped so i bought a new gear, and once again one the first day that i got them they got striped so please can some one tell me what i am doing rough.
RE: Can any one help me with my RS4 3 evo?
Which gears? The spur gears on your 2-speed or the differential gears?
If you keep stripping SPUR GEARS, you need to adjust your gear mesh. Loosen the engine mount screws and move the engine until the clutch bell and spur gears have a very small amount of play between them. Then threadlock the engine screws and put them in tight.
Its the spur gears, and i can not do that because the hole where the screw goes in is so small that the screws can not move to the side, and next to the screw holes is another pare of holes that are much bigger but i can not fit my engine screws in there.
Ok, yours probably uses the tapered engine holes, from what I understand by reading this. Just buy the engine mount that will use the other pair of mounting holes (as hpi apollo said) and adjust away...
It should be no more than $10.
Where can i buy them? because i live in South Africa and it is realy hard to get models and parts at such a cheep prise. Here they are at lest 200 bucks and if there is a good store will they deliver to South Africa? I would like to see this engine mount, so if you have picture of it please send it to me on: [email protected]
Thats if you can?
Thats if you can?
if you have the nitro star .15, you cant use the engine mounts, the engine has the mount built onto it so they wont work, i just swapped my hpi .15 for an os .18 cv-r and had to buy the mounts to put the os engine in and use the elongated screw holes on the chassis, the hpi .15 is in a fix position on the rs4 3 evo. maybe your cluch bell has a problem??
So tell me more about the os.18 cv-r? Can it fit on my car and if it can how much would i cost? and how powerful is it to the T-15?
CA
ORIGINAL: ehroof
