Problem with savage 25
Old 11-19-2006 | 01:27 PM
Default Problem with savage 25
I just got a savage 25 and it starts up no problem but when i hit the throttle it goes no where. The engine revs like crasy but nothing happens but if i pick it up off the ground i can see the drive shafts spinning so from the outside everything looks like it is working correctly, internally maybe another question. Any one have any ideas?
Old 11-19-2006 | 02:30 PM
hpi apollo's Avatar
Default RE: Problem with savage 25
clutch.....
Old 11-19-2006 | 02:43 PM
rcsavager's Avatar
stripped gear maybe
Old 11-22-2006 | 07:28 AM
itsnotskidding's Avatar
or the diffs have gone...????.... check spur, check clutch, if not diffs...
Old 11-23-2006 | 02:05 AM
hi do ya ear any weird noise coming from diffs , i had that problem on my savage but i ran full throttle into a ski doo and my gear in my front diff broke but i was still runing on 2x4 ,so if you see the shafts moving under to the diffs its not the clutch ,must be in the diff ,but I'm no expert
