3pk problem
NY
like its werid becasue when i turn up it goes left and when i go down it turn right, So how can i do it to make it the opposite, please help
digital servos are needed if you want to operate the radio in HRS mode. This allows the radio to have insanely fast reaction times. Since digital servos process and send out signals and respond to signals a lot faster than analog signals they are ideal for this application, and are in fact required because of the HRS system's design.
ok you should have some switches on the controler, flick the switches around until it is right. do one switch at a time if it does somthing else switch it back. make shure you test it each time you flick a switch.
