Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Car General Discussions
Today was my first run in a while......... >
Old 02-14-2003 | 06:57 PM
Default Today was my first run in a while.........
.........the first since my last parts breaking crash, and also since I replaced the radio, rear tires, and installed the MIP 4N1 clutch. Today was the first day it wasn't snowing, blowing, too cold, or all these things combined.
The Airtronics Blazer radio is leaps and bounds better than that the POS Ace Jaguar. When you trun the wheel, it turns NOW, not when the servo feels like getting around to it as with the Ace. All the controls are wonderful, and the transmitter itself feels very ergonomically correct.
These Proline rear tires get some serious bite compared to the stock tires. This thing actually wheelied a couple times today, something it never did with the stock tires. This thing is going to be a handful when I get the Fantom engine installed.
Thanks to those of you who recommended the MIP 4N1 clutch. This thing is much nicer than the factory clutch. The engine idle speed can be set quite a bit higher now without the truck moving, and even though this clutch seems to engage more smoothly, the second you hit the throttle, the power is at the rear wheels instantly!
One thing I noticed, the rear end seems to sit a bit low, and when I have it running at full throttle, I noticed there isn't much clearance between the chassis and the ground. I think I'll install some more of the ring spacers which are installed at the top of the shock springs. This should make it sit a bit higher.
I'll give a full review after I install the Fantom engine for those who may be interested.
Old 02-14-2003 | 07:27 PM
You're makin me jealous, we've had rain all week here. Did give me time to take the truck apart and clean it though. This weekend is supposed to be nice and sunny, so I figure it's time for some nitro!
Old 02-14-2003 | 08:30 PM
Darkroland, have you run on any of the tracks in the area? Also, is your name Stephen King related?
Old 02-14-2003 | 08:41 PM
My Feedback: (16)
grampi.....you just about have a new rig there "AGAIN". Once from the factory....and now with all of your updates!
When you get your new engine....maybe you should change your name from grampi.....to Fantom Man?
I'm interested in hearing how you like the Fantom engine when you get it in.
Old 02-14-2003 | 09:16 PM
Reddog,
Yes it is SK related, it's excellent that you picked up on that!
Also, I haven't really run on any of the tracks. I went up to Mike's R/C, but they weren't doing nitro (it was too cold that day).
Also, i've only been running my truck about 1 1/2 weeks, so I'm trying to get a better feel for it and get it solidified (so it stops losing parts) before I take it to the track and get laughed at.
Old 02-14-2003 | 11:17 PM
I'm beginning to have second thoughts about installing the Fantom. First of all, I'm not that great of a driver, mainly because I don't have a lot of driving experience yet, but partially because I'm old and my reflexes aren't what they used to be. Secondly, this thing is pretty darn fast right now, at least I think so anyway. I'm thinking that because the Fantom makes so much more power than this TT .15 engine does, it's going to be a lot faster. I may end up having to limit my throttle end point to only allow the throttle to open half way or so to be able to control this thing once I get the Fantom installed. I guess I will find out here shortly. Oh, I'm still going to do the engine transplant, I'm just not sure if I'll be able to handle all that power. I'll let you know how it goes.
Old 02-15-2003 | 05:01 PM
tsim712's Avatar
I spent the first couple weeks thinking about a new engine, but after I got it broke in and tuned right, I was pretty happy with the power of the TT .15 I'm sure I'll get bored and do a transplant anyways, so I'd like to know how the Fantom works out for you.
and whats up with the rear end of the GT riding so low? I moved the shock position on the shock tower instead of adding more pre load spacers.
tracy
Old 02-15-2003 | 05:39 PM
yea, mine has always sagged a little in rear...thats just a gt...fun though!!
Old 02-15-2003 | 06:43 PM
I never noticed the saggy butt before. I had to replace the rear shock tower as that was one of parts I broke in my last crash. Maybe the shock mounting holes are in a slightly different location. I'll try relocating the top shock mount to see if this helps. I'll also keep you posted on the Fantom. It's due to arrive Wed.
Old 02-15-2003 | 06:58 PM
My Feedback: (16)
grampi.....Your not old....your just "seasoned".
I think you'll adjust to the new engines power once you have it up and running. It's all about adjusting and getting use to the new upgrades.
Go get em "Fantom Man".
Old 02-15-2003 | 07:25 PM
get the rear spring tunning kit and put the red springs on the back and your truck wont bottom out.
Old 02-15-2003 | 07:30 PM
thx nitroman88
Old 02-15-2003 | 09:50 PM
CMO
I don't know, I'm pretty old, and the ol' reflexes ain't what they used to be.
Nitroman
Who sells this spring kit and red springs? Tower Hobbies? What's it called?
Old 02-15-2003 | 10:02 PM
here you go grampi. it comes with 8 springs, 2 of each kind.
http://www2.towerhobbies.com/cgi-bin...?&I=LXBVG0&P=7
Old 02-16-2003 | 01:07 AM
Cool. Thanks.
Old 02-16-2003 | 02:23 AM
My current set up looks like this:
Gold springs with 40wt oil, shock mounting position is in the C position on the top and B position on the bottom (in the rear).
With this set up I'm still bottoming out fairly easy on jumps over 2 feet in the air. The problem with this set up is the rear end has started to bounce around a lot more in rougher terrain. It does however help it wheelie when I find good traction.
I can get the rear end up in the air a little more by dropping to the lowest mounting position in the rear but then the axels start to rub on the swingarm.
The RC10GT is definately design with a specific purpose in mind. It is however a blast to bash it around a little.
Old 02-18-2003 | 01:09 AM
I take it the green springs in the set are the same as the factory springs? I have green ones on mine now. It looks like the rest of the sets are longer. These should do the trick. Thanks.
Old 02-18-2003 | 01:12 AM
the green ones suck i dont know why they put them on the gt stock, you cant do any kind of jumping without bottoming out.
Old 02-18-2003 | 01:22 AM
Tower also sells these springs in separate pairs for $2.39 a pair. I suppose I could order the 3 sets (not the green ones), and save a few bucks. I certainly don't need another green set. That should set me up with the springs I need.
