how much% (^.~)
GA
RE: how much% (^.~)
Well they have 3 different formulas so it depends on what formulas. The only really confirm the content in the HP8 formula. Not a big fan of Blue Thunder myself.
http://www.dynamiterc.com/Products/B...r/Default.aspx
RE: how much% (^.~)
Hey I run 10% and it says that it has 18% caster oil The oil enancement it is the caster oil . So I don't know if this helps but the fuel I run has it all listed right there on the bottle
RE: how much% (^.~)
I run wild cat 10% nitromathane and 18 % caster oil and the there is other stuff in there to. But I do all racing so I like the 10% use it for break in and all the time in all of my rides. I get it from tower for a really good price I buy it by the case . And I will tell you now that someone or every one will have there say about what is the best. I have been doing this for over twenty years and a old timer turned me on to wild cat and that's all I use so you use what you think is the best or if someone you know can tell you from their own use then go with what they say. Good luck. Eric
