Servo batt pack?
PA
Servo batt pack?
I have 2 1200ma nimh packs when i charge what amp should i charge @? Is the lower the amp charge better for the packs? I charged @.5amp it took awile but the pack did not get as warm is this a good idea? or should I charge @ a higher amp?
RE: Servo batt pack?
Charge them at 1.2A, it will take approx one hour from dead. 1200mAH = 1.2 amps per hour...easy. You can get away with charging receiver packs at 2A for a faster charge, but it's not very good for them in the long run.
The only thing that would happen if you charged it under 1.2 amps is less runtime=more chance of run-away just charge it at 1.2 amps.
ORIGINAL: nitro _ burner
