Reedy Brushless neo1 3star broken...HELP
I purchased a reedy brushless sytem and it only ran through 6 battery packs and then the shaft came loose inside the motor.[:@] It slid outward about 1/8" ripping up my spur gear. Something broke loose inside and I'm wondering if anyone else had a problem with these motors and how to fix it. The warranty I believe was for only 90 days and that time has come and gone. []
Thanks, Jim
Thanks, Jim
RE: Reedy Brushless neo1 3star broken...HELP
all i can say is call reedy and explain to them what happened. if you try to fix it yourself, they definately wont do anything. good luck
Thanks, I'll do that Monday. Just wanted to know if anyone else here had the same problem. If so, I won't be purchasing another Reedy brushless motor.
MI
Sounds like the rotor came loose from the shaft. You can use JB Weld to fasten the rotor back to the shaft. I had this happen and this fix worked. Make sure to use the slow curing JB.
Reedy said send it back and they'll fix it minus the shipping charges. They also said there was a bad batch of these motors where the rotor came loose.
MI
Yes, when they first came out, there were a bunch. If you decide to fix, yes the JB held under any conditions. Your motor will melt before it gets too hot for JB.
