Is it ok too?
I charge my 6v hump packs after every run nomatter if their empty or still half full.Is it ok if i do this or should i only recharge when their empty? Thanks.
Yes, it's fine to recharge while the battery still has juice, but keep an eye on the battery and make sure it doesn't over heat....this is a perfect example on why to own a charger that has the discharger feature (think that's what it's called)
so do nimh, but to a much lesser degree. You would double the useful life of it if you discharged it properly each time, but like others say, it doesn't really matter, I don't do it either.
