Where to read temp.
Where to read temp.
Hello guys,
I just got a HPI MT2, and I'm doing the best to tune it.
When reading the Temp. of the motor where should I point the meter:
At the engine, plug, etc?????
CA
RE: Where to read temp.
If you are supposed to take the glow plug temp what is the purpose of those temp gauges that wrap around the cooling head? Wouldnt that be inaccurate?
PA
ORIGINAL: nick2618
Is the temp hotter straight down the top then on the side? Please say no... lol
GA
ORIGINAL: iliketobreakthings
you have to adjust it
if your on board temp reading is different than your hand held, move the lead up to the next fin if it's says it's hotter, and move it down a lead if it's colder.
you can't just throw it on and hope it correct
ON, CANADA
Just measure the temperature of the glow plug, measure the temperature of the lower end of the cooling head, write down the difference and remember it. Add it on when reading the temp from lower end of cooling head... Depends on your standards, but its probably not even going to be that different.
cheers
cheers
