What to do
FL
Hi I recently brought a XTM XT2 from a local hobby shop. I broke the engine in and did everything right.
On my first run after the brake in my throttle servo broke[:@], so i went to the shop and they gave me a new servo. Then I came back home and installed the servo and took it outside for a run everything went fine.
The next day I took it out again and did the usual check to see if the brakes and steering where working and then found out that my RX was broken
. I have maybe only put a quart og fuel in it shall I return it or shall I buy get them to get me a new RX please I need a reply by the 17th
thanx
. I have maybe only put a quart og fuel in it shall I return it or shall I buy get them to get me a new RX please I need a reply by the 17ththanx
This is a hobby, things break. If that's an issue for you then return it. If you want to keep running rc's then get the part and fix it.
Also, it's kinda hard to reply by the 17th when you post on the 18th. Unless, of course, you mean the 17th of next month.
