best engine for an RS4?
Old 07-11-2007 | 06:57 PM
Default best engine for an RS4?
ok so... i've decided to get a new engien for my RS4.. i want to get me a 12 engine wich one you guys recommend? not more then 250 i was lookign at some OS but idk.. whats better in a 12?
Old 07-12-2007 | 12:36 AM
My Feedback: (13)
Default RE: best engine for an RS4?
I would go with os they are very reliable and are very well made.
Old 07-12-2007 | 06:39 AM
Hello,
No not OS. Go for a Novarossi then much better in quality and much faster. If you don't got all the money take an .12 of rbproducts.com like the matrix.
Hope to help you
Greets.
Old 07-12-2007 | 06:41 AM
Here a link of the engine.
[link=http://www.rbproducts.com/mainEn.php?part=Products&AR_Stat04=RB%20CONCEPT&Se ries=MATRIX]Matric 3 ports .12 engine[/link]
Old 07-12-2007 | 09:13 AM
hmmm thanks.. i dont think they fit unless i buy the flywheel and all that stuff? cuZ the shaft of the engine where the flywheel is mounted and stuff is too long..
Old 07-12-2007 | 01:40 PM
It's a very good engine. I saw it in real life time.
Old 07-12-2007 | 03:11 PM
well where can i get the parts i need to adapt it on an rs4? the flywheel ect?
Old 07-12-2007 | 03:44 PM
This depends entirely on WHAT YOU WANT TO DO WITH THE CAR.
Do you want top speed?
Do you want ease of tuning?
Do you want your buddies to say "ooooooh"?
Do you want big smokey burnouts?
Do you want ridiculous power?
Do you want to get an economical engine?
Do you want an engine that will last a long time?
Answer all of these questions, understanding that most do not go hand-in-hand (EX: ease of tuning and high RPM are not coming from the same engine. Nor does a cheap, powerful engine exist....)
Once you indentify your goal, suggestions can be made.
Old 07-12-2007 | 05:21 PM
yes, but i can mess with the gears no?
yeah but if it has great performance ill learn how to tune the hard way
well, thats the point of investing 200 300 in an engine
i dotn want to drift burnout or u mean the trail of smoke it leave? then i guess that means power? if so i guess yes?
not really that will only make me spend mad money of parts that will break...
my budget is around 200 - 300
that depends on how much it cost cuz im not gonna pay alot for an engine that will die in short time an average time after i used it enough then is ok if it dies
in resume what i want is speed and power to be able to race and leave my friends in the back or atleast get close to them
Old 07-13-2007 | 11:02 AM
Given your responses and my knowledge of engines....
It sounds like you want something like a high performance, mid RPM, 3 port engine. The engines that will be the perfect balance of your responses above will likely be somethinf like a Picco or NovaRossi.
Those 2 companies have been in the industry for years, incicating a great deal of experience and ability to R&D on a practical level. They are italian, who by established reputation, have a tendency to construct performance machinery with extensive QA/QC. For this reason, I choose them over some of the newer companies. They are also builders for many other companies (OFNA, Trinity, etc.) meaning that many other brands are de-tuned versions of this brand.
Motors of the .15 size will give you great torque, allowing for gearing mods. (A .12 is more limited to lower gearing due to decreased torque). The .15 will not be drastically overpowered, and give a great balance of practical RPM and torque to get the car moving. Italian .15's usually rex higher than US .15's, giving you more top end speed.
A 3 port will be reasonable to tune. A 5 port may require tuning every time you run, may have 3 needles as opposed to 2, and will undoubtedly increase your frustration factor.
They definitely fullfill the "wow" factor.
A 3 port is not a full blown race motor, so it will have a respectable lifespan.
Recommended:
Picco XP series
Novarossi NS or LS series (LS, if you can find one is INSANE)
Look for something that will spin over 37,000 RPM
Old 07-13-2007 | 01:34 PM
thanks for all that information, i was looking at the "Novarossi" engines... seems ill need to buy a different flywheel clutch bell ect right? there is a local Hobbie shop bout 20 miles from me that has them ill see if i go personally cuz well idk how good will it fit my car and the parts i need to buy did not see those engines in towerhobbies :/
Old 07-13-2007 | 01:41 PM
the os 12 osmg1998
Old 07-13-2007 | 01:43 PM
I have what u need.e-mail me.
