Shifting into second gear
I have an exeed Xtreme buggy and when it tries to shift into second gear it will shift then bog. it runs perfectly fine in first gear then second gear it will bog. how do i fix this??
thanks
thanks
TX
Check your settings in the transmission for second if you can adjust it you might be shifting into second too early and this will cause the motor to bog as it falls out of its power band.
