2 General Questions
Old 08-25-2007 | 09:03 AM
Guest
Default 2 General Questions
Hey guys. My T-Maxx rolls very easy, i mean, VERY. I have to slow right down before turning otherwise it just rolls, so why is it doing this? Also, what is the correct way of stopping a nitro engine? Pinching the fuel tube, stopping the flywheel or covering the air filter. Not sure if there is any more ways of stopping the engine.
Thanks.
Old 08-25-2007 | 09:29 AM
DaveG55's Avatar
Default RE: 2 General Questions
It rolls because it has a high center of gravity. You can reduce it by lowering the truck by making suspension adjustments, widening the stance and just plain learnng how to drive the truck.
The main ways to stop the engine are; Pinch the fuel line, block the exhaust, stop the flywheel, and block air flow to the carb. As to which is best, well that's pretty much a matter of debate and personal opinion. Some manufacturers reccomend pinching the fuel line, some stopping the flywheel and some blocking the exhaust. Very few reccomend blocking the carb. My preferd way is to block the exhaust but probably the best for the engine is to stop the flywheel. The only one that can be harmful is blocking the carb because of the possibility of getting dirt/debris in the carb.
