steering gone mad
I bought a heavily hopped up baja a few weeks ago - no probs, until now.
The steering servo is a Ko Propo digital 8044mg.
When I turn the car on the front wheels shoot over to the right and movement of the transmitter steering wheel has no effect, why would this have just started to happen. I have charged the battery for 6 hours (checked all batteries) still no proper steering - Grrrh!
I have even switched the old/standard battery pack over just to see if the connection was faulty with the new larger battery pack. i am wondering if I have been given a non compatible charger pack by mistake.
I am fairly new to all this so any suggestions will be welcome.
have u gave it a knock or something take the servo arm off turn on your electrics and reset the sterring and then put the arm back on and the problem should be solved mare
turns out the horn on the servo was slightly threaded causing it to slip, £3.99 to fix, thank god, new servo costs £120 notes - thanks for your advice.
