Brake Pad question
My brake pad on my jato got over 270 degress. I was doing some high speed runs.
Anyways the brakes pretty much failed maybe only had about 20% braking power. They say there made of composite materials. So my question is do i need to get a new brake disk or next time i run it will it stop like before it got over heated?
Well i ran my truck just now and to answer the question the pad is dead. It will barely stop the wheels spinning when they are off the ground...
ORIGINAL: nick2618
ORIGINAL: rctruggy
If you burnt the surface maybe you can turn them the other way and use them again.
there are brake pads on both sides.
have you done the brake mod, where you use fuel line instead of the spring? do that. and 270 aint nothin. mine were over 400 at one point, and they are still fine. if you havent done the brake mod i suggest you do it, and when you go for new disc get a steel one off of ebay
I have the brake mod and i sanded them like suggested and they worked great for a while again. Then they started to fade a little not to much. But i was doing a high speed run and hit a bump and the truck did some cartwheels. And somewhere in that process the disk broke in half! So now i have a new one.
