Stage-D solid axle
Old 10-11-2007 | 12:32 AM
Default Stage-D solid axle
What do you guys think about the Stage-D solid axle conversion? What exactly does it do and is it worth it?
Old 10-11-2007 | 02:26 PM
iexion's Avatar
Default RE: Stage-D solid axle
Honestly if you a big fan of drifting and you want to drift nitro then spend the $170 to get the stage-D conversion kit.
If i ever wanted to get a rs4, i would start would the Stage-D conversion first then build it up from there.[:-]
Old 10-16-2007 | 09:23 AM
It locks your rear end like a spool in a real car. Makes it much easier to drift with or without the stage-d conversion. Highly recommended by me if you plan on drifting a majority of the time.
Old 10-17-2007 | 09:48 PM
Yeah, I alredy have the stage-d conversion or I wouldn't be asking. didn't know if it was for the front or rear or both. I wanna be able to drift when I have the drift tires on and plan on doing it but just driving around I wanna be able to drive like normal.
Old 10-22-2007 | 08:16 PM
Well, thats a problem. The spool affects your turning radius tremendously. Normal driving will be affected because you can't turn as tight. If I were you I would just buy a real thick diff oil and try that.
