engine running wrong
Old 10-15-2007 | 10:04 AM
Default engine running wrong
Well about a month ago i bought and installed a new engine in a truggy, every thing was going well its been run in properly and has been tuned (but i think thats the problem). When ever it reaches a fast speed and throtle has been down for about 4 - 8 seconds it will start to choke and if still help down will cut out. Have any of you guys got any ideas on what it could be?
Thanks - crowdie
Old 10-15-2007 | 10:10 AM
mazdab2600's Avatar
Default RE: engine running wrong
ORIGINAL: crowdie
Thanks - crowdie
at wide open throttle(wot).it bogs down?
your too lean on the high speed needle(hsn).your running out of fuel at wot.
back it out 1/4 turn till it runs at wot with a smoke trail and watch your temps.
Old 10-15-2007 | 10:14 AM
jatoracing33's Avatar
yea...back off the hsn 1/4 turn then go from there, might need a little bit leaning, but no more than 1/8 turn
Old 10-15-2007 | 11:15 AM
Yep I agree with above post's, when your engine seems like its running out of fuel it probably is and your running to lean.
Old 10-15-2007 | 12:51 PM
ORIGINAL: haasjj
Well thats the problem... its got crap loads of fuel left it lasts ages!
Old 10-15-2007 | 01:21 PM
Anthoop's Avatar
I think he's trying to make you see that the condition your describing is similar to when you run out of fuel....yes?
Meaning that the high speed needle needs adjusting(as above)..just an 1/8 of a turn at a time then run it up and down to see the difference,just always ensure you have a nice trail of smoke.
Old 10-16-2007 | 09:42 AM
cool thanks, ill tune it when its next sunny or not raining... ill keep you posted
Old 10-16-2007 | 12:20 PM
ORIGINAL: crowdie
ORIGINAL: haasjj
You got it thats what should happen when you run lean you will have alot of fuel left and run for a long time on a tank. Sorry i should have explained better when your engine seems like its running out of fuel its running lean it doesn't matter how much is in the tank.
