guys, need help! again
ok when you said my engine hydrolocked, it worked. turned it over, and then today i started it. it started then second run it didnt. the rotostart couldn't start it again because it was stuck. i checked the flywheel, but it was turning. plz. help
whats stuck
the engine back plate (where the roto goes in)
or the roto
ur battery charged?
might be flooded again...
or if ur saying the flywheel moves but not the engine
the clutch nut is not tight enough
or u broke the flywheel collet
pics would help
or the roto
ur battery charged?
pics would help
when i turn the flywheel, the piston goes up and down. everything is charged. the one thats stuck is where the rotostart goes in.plz. help. im still in break in stage.
No the problem is the motor is to new and tight to turn over with the roto starter, So just warm it up with hair dryer and you will be good to go. I had the same problem when I first put roto starter on my SH 28 just warm her up and you will see it will turn over with no problem and then as you break it in it will not need to be warmed up . Give it a try.
ya i thot that 2
but he said the piston moves in the cylinder
and that the flywheel moves?
and that also as you stated above
can also be the problem
what engine is it?
what engine is it?
