Not getting fuel?
Old 02-03-2008 | 04:04 PM
Default Not getting fuel?
I have an exceed rc truggy and i am having some problems with it running. It acts like its not getting fuel. I put a little fuel into the carb and it and pull the start and it fires up for a few seconds and then it dies it acts like its not gettin fuel. I need some imput. please let me know.
Old 02-03-2008 | 04:21 PM
Default RE: Not getting fuel?
Did you try priming the engine?????? When trying to start it cover the exhaust stinger with your finger and look at the fuel line, you should be able to see fuel go up through the fuel line and get to the carb. Once the fuel is at the carb take your finger off and try and start it, if that doesnt work you may have a blockage within the carb. Take the carb off and clean the carb out, make sure to note where the needles are(how many turns out they are from closed) so you know where to put them back when your done. Use a carb cleaner solution or you can use some fuel to clean the carb with. Just make sure not to bend the needles when handling them.
Old 02-03-2008 | 04:26 PM
I put gas into the carb and it starts long enough to burn the fuel and then i look at the fuel line and it has a few air bubbels in it but they dont seem to move when i prime the engine. it just seems to not be pumping is that a good sign of a cloged carb?
Old 02-03-2008 | 08:09 PM
46u's Avatar
46u
Check the fuel lines for a hole, if it has a fuel filter check it to make sure it is sealed and make sure the fuel tank cap is sealing. Sounds like it is sucking air somewhere. You can take the fuel tank and fuel lines off plug one fuel line submerge the tank and lines in a sink of water blow in the line that is not plugged and look for bubbles.
Old 02-03-2008 | 08:14 PM
check that the exhaust manifold and coupler are tight/undamaged too
Old 02-03-2008 | 11:18 PM
46u's Avatar
46u
One other thing I have seen the fitting on the tuned pipe get stopped up before.
