soldered???
Old 02-05-2008 | 09:59 AM
Default soldered???
OK WHAT IS THE TRICK YOUR IS THERE SOMETHING IM DOING WRONG IM TYING TO SOLDERED WIRES ON MY MOTOR I CANT GET IT TO STICK. AND I AM USEING ELECTIC SOLDER. PLEASE HELP?
Old 02-05-2008 | 10:04 AM
associatedrules's Avatar
Default RE: soldered???
Use at least a 40 watt iron, and don't forget to tin the solder tabs on the motor as well as the wires. To tin the motor tabs put the tip on the tab and have the solder melt onto the tab and not the iron itself. Also make sure that the tabs on the motor are clean before you try to solder to it.
Old 02-05-2008 | 10:24 AM
ORIGINAL: associatedrules
good answer, tinning is the key.
Old 02-05-2008 | 12:05 PM
Try roughening up the surface where you are trying to solder onto.
I can solder my motor wire easily with just a 30watt iron.
