warhead evo fuel problem
NC
Can someone help a newbee? I am having a problem tuning my evo. I noticed I am getting bubbles in my fuel line at about 1/4 throttle. I replaced all fuel lines and also removed fuel tank, pressurized and found no leaks. Is this normal?
IN
[quote]ORIGINAL: fast84stang
[/quote
there's a really good thread about warhead goin on here, so just use search, very helpful.
to answer ur q, it's not normal,the problem might be the fuel cap is not tight enough especially when the truck is movin and makin' vibration,,,my easy fix for it is i installed a scratch built gasket and fit inside the fuel cap and i inserted a screw or tiny rod in the fuel cap spring to make it tightier...
