Engine temp..
Old 03-06-2008 | 11:30 PM
Default Engine temp..
Where is the best place to get the most correct engine temp for running?
Old 03-06-2008 | 11:37 PM
Default RE: Engine temp..
ORIGINAL: fupuk
I put my temp gun on the head and check the glow plug.
Old 03-06-2008 | 11:38 PM
silverj's Avatar
POint it from the top of the head down at the glow-plug!
Old 03-06-2008 | 11:39 PM
if you mean where to touch the sensor on the thermal gauge, the best place is at a 90 degree angle to the exhaust port just under the cooling head or if you are using a wire type sensor put it oround the head 1st flange up from bottom
Old 03-06-2008 | 11:54 PM
I am new to the hobby and have a Pro Exotics PE-1 temp gun. Because that was what my local hobby shop had in stock.
Old 03-07-2008 | 12:24 AM
ORIGINAL: fupuk
Thats the most used temp gun So yea, just point it straight down at the glow plug.
Old 03-07-2008 | 12:31 AM
Will it still give an accurate temp without getting that close to the glow plug?
Old 03-07-2008 | 02:03 AM
ORIGINAL: fupuk
Yep, I forget the exact numbers but, basically it will give accurate readings within a few inches or so.
