whats postive and negative?
Not usually. The whole point of using back and red, is so that everyone always knows, red is positive, black is negative. There are no exceptions that I know of.
ORIGINAL: Deftones123
isnt it reversed on a123 cells, black is postive and red is negative?
they are marked with a + sign for positive
and a - sign for negative
there are other ways to identify the pos/neg terminal of a battery also if they are not physically marked
if a company were to mark a positive lead in black and a negative lead in red then they would be leaving themselves open for some serious lawsuits as they would be going against international convention
there are some things in wiring that are just not reversed
like the green wire in house wiring is always the earth ground, red and black are always positive and negative - respectively
It isn't always black and red, it can also be black and white, blue and yellow, orange and black, yellow and black, etc. The colours don't matter, what matters is that the darker wire is always negative.
EDIT: House wiring is AC, there is no positive or negative.
ORIGINAL: hands without shadows
but the source power is always red and black, as in from the battery
you don't get into the other colors until power starts to branch
and house wiring is ac and there is no positive and negative per say
but my point was wire colors and how some are constant
green in house wiring is always earth ground
black is always hot and white is neutral
