SETTING THE ESC, DID THAT NOW???
IL
ok now i need to know how to set the esc. yes im a beginer and i just wnat to do things the right way . i have a 12t with reverse i think the brand is intelspeed ? at least that is what it says . and has one black button to push . hopefully someone can help .
this comes from my other topic that the truck was going by itself at times . i got the trim to wehre the lights on the esc arent on and is giving no power that way ( by the trim ) but now i need to find out how to just reset the esc and fine tune it ! thanks again !
PA
Is it this one? If so here is the owners manual in pdf format.
http://manuals.hobbico.com/dtx/dtxm1070-manual-v1_1.pdf
IL
ok i reset everything and it still has a mind of its own like its condemd or something i can turn it on and turn on the transmitter and then it does what it wants i try and go in reverse and it does but it turns the other way . i try and go forward and it does BUT until it hits the wall . i dont want that . i t is just sitting here and i can move the trim but it still sounds like the motor is itching to move . i know the transmitter and the servo are old could that be my problem?also it sits here and the front tires go back and forth like there turning it seems like the darn thing is out of some crazy horor film . I NEED HELP !
