TRIM SETTING
IL
EVERTIME I TURN THE TRUCK ON I HAVE TO SET THE TRIM IS THIS NORMAL ? NO MATTER IF I TURN IT OFF FOR 5 MIN OR CHANGE THE BATTERY I ALWAYS HAVE TO SET THE TRIM ??
IL
ok sorry for not enough info . i have a losi xxx-t with a intellispeed 12t modified esc and a futaba controller. IF YOU LOOK UNDER THE POST POWER BREAK UP THATS ME TOO AND THERE IS A PICTURE OF MY SET UP . it is the trim that controlls the throttle . thanks for the help now hopefully this will help someone help me !
MO
I have never heard of this, I would guess it is a problem with your radio itself. Try to borrow someone's radio, if that fixes the problem send it in for repairs or get a new one.
Helpful hint, the caps are annoying, less caps might result in more help from others around here.
