Will It Run???????
Old 03-10-2002 | 08:12 AM
Default Will It Run???????
I have a HPI RS4 with the HPI .12 on it and it has been sitting with fuel in it for the last year. I tried about six mounths ago and it didn't run. The reason I didn't think it ran because of the bad fuel in it. Do you think this is this true. I pulled it out today and started cleaning it and was wondering if it will run. I'll try it tommorow with new fuel. Do you think it will run???????
thanks
jim
Old 03-10-2002 | 03:27 PM
JohnVH's Avatar
My Feedback: (38)
if its got compression and the fuel system isnt clogged it sure should run!
Old 03-10-2002 | 07:10 PM
What if that castor turned into varnish?
Old 03-10-2002 | 11:54 PM
JohnVH's Avatar
My Feedback: (38)
I meant with new fuel, Ive used fuel that was a couple years old without problems.
Old 03-11-2002 | 09:43 PM
Well I ran it yesterday and it ran. But it ran like crap. I drove it around and then it started bogging down alot. When it killed i checked the compresion and there was none. i could pull the starter with my pinky. DO you know what this means.
Old 03-11-2002 | 10:03 PM
Was it hot at the time? A hot engine may be easier to pull through.
Was the glow plug loose?
Was the head loose?
What fuel did you use?
Old 08-18-2010 | 11:47 PM
Bluethunder3320's Avatar
Default RE: Will It Run???????
Make sure the head is tight and glowplug has a seal ring and head gaskets ok aaaaand if its bogging lean it up
Old 08-18-2010 | 11:59 PM
jatoracing33's Avatar
I don't want to sound like a jerk, but why did you reply to an 8 year old thread?
Old 08-19-2010 | 11:22 AM
Whats so "8 year old" about helping people with their cars? This is rcu...
Old 08-19-2010 | 11:33 AM
The guy who started this thread hasn't been online for 7 years.
And I think you misread the "8 year old" part...the thread itself is 8 years old.
Old 08-19-2010 | 05:35 PM
Haha wow my bad... Did not see that!
