RS4 EVO ENGINE PROBLEMS
Old 08-12-2008 | 10:17 AM
Default RS4 EVO ENGINE PROBLEMS
I'm new to HPI. I have the RS4 3 EVO+. I already did the break in, ran about a quart of O'Donnell 20% thru so far. The car sat for about a month without running. Now when i try to run the car, if i take off the glow starter it will stall. I changed the glow plug(R5) and put after run in it after i ran it last, i did remove all the fuel also. It just won't run without the glow starter on it. Anybody? Help??
Old 08-12-2008 | 11:05 AM
Default RE: RS4 EVO ENGINE PROBLEMS
im having same problems but each time i do throttle it stalls and revs highger when idle.
i blame my dad for turning the needles anywhere
Old 08-12-2008 | 12:01 PM
It ran perfect during break in. I don't understand what happened. Idle's fine. Any suggestion.
Old 08-12-2008 | 12:15 PM
It may be you're running too rich. When the glow igniter is taken out, there is too much fuel for the plug to burn.
Try leaning it out a little.
Lolzpl0x, you can always reset the needles to factory you know. The HSN and LSN are flush if you are runnign stock engine.
Old 08-12-2008 | 01:49 PM
huh, wasnt it 3 turns? i ran it today and managed to get a point where i could accelerate but too much oil was spitting out so i tried to tune...then..you now
Old 08-12-2008 | 02:41 PM
I really don't know I haven't adjusted the carb at all not even after break in. I guess i will try to lean it out a little and if not go back to square 1 and put it back to break in specs if it isn't already and try this weekend one more time. thanx
