what could be wrong?
Old 09-20-2008 | 09:50 AM
emaXXman123's Avatar
Default what could be wrong?
http://www.maxamps.com/Power-Supply-10A.htm
well about that power supply i got from max amps something is kinda weird about it..i mean it works perfectly fine just that the postive terminal on it is smaller than the negative one..i tried plugging in banana plugs that came with my charger and they only fit into the negative terminal and wont fit in the positve one. if anyone has had problems like this is there someway that i could fix it?
thanks,
brian
Old 09-20-2008 | 11:10 AM
My Feedback: (325)
Default RE: what could be wrong?
Is it the diameter or the length that is trouble?
Usually it is the male plugs that get worn. Many times they can be bent to make a good connection. I've never seen the females ones differ in diameter.
Old 09-20-2008 | 11:13 AM
no i just got it in the mail yesterday and i cont use my lipo now[:@]
i looked up some stuff on it and it says it uses 3mm banana plugs and i have some and i think the postibe is 2mm and negative is 3..
Old 09-20-2008 | 11:21 AM
and that little black adapter thing that is in the picture doesnt fit in the plugs either..even hen the postive one is smaller that the negative one and still wont fit into the power supply
Old 09-20-2008 | 12:34 PM
The adapter in the picture if for the wall plug to convert to Euro wall plug style.
I'd say contact who you bought it from, take a pic of your out put ports and email it to them.
Old 09-20-2008 | 12:37 PM
oh haha silly me..
hey ill post some pictures...
Old 09-20-2008 | 12:46 PM
here the pictures.
ID:	1036763   Click image for larger version
Old 09-20-2008 | 01:38 PM
My Feedback: (325)
You probably got one that slipped thru without the ID being finished machined. It should be same as the other one.
There's lots of sizes , but the standard bananas are all the same.
OR they could do that for polarity mix-ups.
Old 09-20-2008 | 01:42 PM
is there any way that i could get it to work without having to ship it back?
Old 09-20-2008 | 01:43 PM
My Feedback: (325)
If it was mine I would drill it out to the standard size. Be careful brass grabs sometimes.
Old 09-20-2008 | 01:50 PM
you mean with just a regular drill bit right?
Old 09-20-2008 | 01:51 PM
My Feedback: (325)
Yes. Take some effort to ensure it doesn't spin in the housing or you may wind up with a twisted wire, broken power suply.
Old 09-20-2008 | 01:53 PM
My Feedback: (325)
You may also use an alligator clamp temporarily making sure not to pull too much current through it and careul it doesn't short out. I would hate to see it ruined since they will not refund onec it is "modded"
Old 09-20-2008 | 01:59 PM
how would i hold it when its that far into the power supply?
Old 09-20-2008 | 02:16 PM
actually i dont wanna risk the warrenty..so im not gonna do anything to it..im just gonna see if i could find some 2mm banana plugs and 3 mm banana plugs....
Old 09-20-2008 | 02:19 PM
they could have made it that way so you cant space out and put the wrong plug in the wrong side i think it would be easy change the clip off your charger positive to a size that fits .
Old 09-20-2008 | 02:50 PM
but what banana plugs would be made like that?
