help Thread Locker
Old 10-12-2008 | 06:56 PM
Default help Thread Locker
hey i just got some 23mm adap
I put thread locker on the nuts and now i cant remove them with out
starting stripping out the rims
need ideas to remove or make it softer to remove the nuts
need ideas please.
Old 10-12-2008 | 07:20 PM
budha24's Avatar
Default RE: help Thread Locker
UH oh what color locker did you use please say blue and not red!
Old 10-12-2008 | 07:34 PM
warheadforever's Avatar
ORIGINAL: hse32
need ideas please.
O.K. just stay calm. LOL Take a hair dryer, and heat the nut up, and it will come off without a problem.
Old 10-12-2008 | 07:37 PM
budha24's Avatar
the reason I wondered the color is if its red your may have to heat up your driver as well and rock it left and right to wiggle the threadlock apart.
Old 10-12-2008 | 07:47 PM
Snipin_Willy's Avatar
Yep, use some heat.
Old 10-12-2008 | 07:52 PM
ORIGINAL: budha24
Just hope he didn't use green.............
Old 10-12-2008 | 07:55 PM
budha24's Avatar
where I used to work we had to use black I was told that if you had to use it to be sure you never had to open the tool again. If fact that stuff was as thin as water which I found kinda funny.
Old 10-12-2008 | 07:57 PM
With Green, if you put it on, it isn't coming off....... Well, unless you want to drill the screw out.....But yea, it is as then as water. LOL
Old 10-12-2008 | 08:08 PM
budha24's Avatar
Wierd it does seem the thinner the tougher. For rc if I do use locker I stick with blue. Idea being anything on a vehicle can be broken dont want to make the job of repairing harder than it has to be.
Old 10-12-2008 | 08:26 PM
It does seem that way.......I mostly use Red...... the real stuff (made by 3M) I just heat it up a bit.
Old 10-13-2008 | 12:40 AM
I use blue on everything except motor pinion set screw and motor/engine mounting screws which are red.
