Bearing Cleaning
RE: Bearing Cleaning
I heard about this awhile back, but never realy looked into it that much. https://www.speedtechrc.com/store/eb...id=393&id=7581
FL
That's kind of neat, but I've always just used brake clean and blasted it directly onto the bearing. Brake clean is cheap, you can buy it anywhere, and it works great. After I've cleaned them I relube them with an oil called Tri-Flow. I buy it from my local bike shop. It's perfect for lubing anything on RC cars. Dirt doesn't really stick to it, it makes everything real slick, and it lasts a long time.
CA
The best way of bearing cleaning is to take the shield off the bearings, use motor spray or nitro cleaner in RPM bearing blaster, and use light bearing oil for diff parts (trinity bearing oil) and heavier oil like 3 in 1 oil for bearings like the bearings in the hub carriers.
Never tried [link=http://www.teamfasteddy.com/index.php?main_page=product_info&products_id=2932& zenid=8bc4df0c7173ef082f902b74e5a6e14a]THIS[/link] but Team Fast Eddy has some good products.
I use Lightning heli lube from Readyheli. I also use "The Greaser" tool from Readyheli, both work excellent.
If I am just cleaning out a old used but clean bearing I tend to just squeeze new grease into them. If it looks dirty I will soak in WD40 and blast 'em and then relube.
ORIGINAL: TornadoGuy
Sounds good Technex![sm=biggrin.gif]
If you want P.M me for links to each product. Or a simple google search for Readyheli and you'll be on your way. Best shop ever.
CA
You are suppose to clean your bearings when you are doing you normal maintence taking apart your car and you notice that at least 1 bearing is a little griity when you spin it. That is when you clean them. If you run on pavement that doesnt mean you never have to relube them.
I only tend to clean bearings when I have them out and they feel in anyway gritty (not very often), normally it's to late by then and I just replace it all. I use rubber sealed, helps tons. You'll find that many bearings do not come pre-greased, quite a surprise even though it's new.
I wouldn't clean a shielded bearing unless you can for sure see you need to (its gritty). A new bearing will work great for a LOOOOONG time with no maintenance under normal conditions, but once you remove the shield and clean and lube a bearing, you need to make it part of your normal maintenance, since it will need to be cleaned/relubed fairly often after that.
When one of my bearings goes bad, I replace it with a rubber sealed bearing, other than that I dont think about them...not worth the hassle...
ON, CANADA
depends on where you get them... You can end up paying anywhere from $1-$5 or more a piece... one of the hobby shops near me buys them in bulk, and sells them for $1-$2 each... just remember that you dont HAVE to get bearings that are labeled as being for your specific vehicle... you just need to know the bearing size. like 8x16x5, would be 8mm inside diameter, 10mm outside diameter, and 5mm thick.... generally buying more at once is a better deal, and buying a tube of the same size will almost always be a better deal than buying a "Kit" made for your vehicle... You can get a tube of most sizes (rubber sealed) for around $10.
GA
For the most part I run rubber sealed bearings on my off road RC vehciles and just wipe off the outside. Since bearings are only .90 to 1.00 I just replace them when they get feeling gritty or rough. I feel it is just cheaper then what time it takes as well as the cleaners and oils.
The "greaser" is great as mentioned abouve. When you press the grease, you actually force the old grease out and new in. Works well, even on rubber sealed although it required a more force. I made my own "greaser", but I have access to a lathe
