project 4tec
Old 06-04-2003 | 01:01 AM
Default project 4tec
back in febuary i bought a nitro 4tec on ebay. i had some trouble getting it. well i finally got it and it is in bad shape so im going to fix it up and make it nicer. its the pro .15 edition. i need some help with it. where you put the pull start it just has a little shaft coming out of it so im geussing it needs a back plate? does any one know where to find one i couldnt. thanks.
Old 06-04-2003 | 03:48 PM
It's suposed to have a little shaft there, just large enough for the one way bearing. The trx pro 15 has a problem leaking oil and making the one way bearing not catch. Most people will drill a hole in the middle of the pull start/ electric start and spray some degreaser on the one way bearing.
