Dumb Question?
My Feedback: (7)
FL
Dumb Question?
I have a traxxas rustler vxl and a 3s 3300mah lipo battery, and I wanted to know if there is a way to make it go faster than 70mph? I want to do speed passes with it.
RE: Dumb Question?
Can it handle a 4s lipo if not then you need an esc that can handle higher voltage lipos. You can also change gearing but you dont want to go too high otherwise everything will overheat.
AB, CANADA
RE: Dumb Question?
the monster mamba or novak hv.
I'd just say try a higher capacity lipo. If you're 3300mah battery is a 20C lipo then it will only put out 66amps. The VXL motor has a rating for 100amps. A 5000mah 20C battery is about perfect for it.
AB, CANADA
RE: Dumb Question?
ORIGINAL: TRXRUSTLER
my lipo is a 3s 3300mah 25c.
will a Mamba Monster Max work with my Rustler VXL?
I'm talking about an ESC, it will easiliy control the VXL motor. Whether you fry the motor on 4s or not I don't know.
RE: Dumb Question?
I would also agree with the lipo thing you would want atleast a 5000mah 20c lipo.. You can play around with it, But you need atleast 100amps.. You can always go with a 4s lipo and run a Mamba max.. If you decide to run the mamba max just make sure you disable the BEC and run a battery pack or an external BEC
GA
RE: Dumb Question?
Bottom line, a bigger better lipo will help with the esc you have but the motor will only turn so many rpm on 11.1v. If you want more rpm then you'll need to go to something that can handle higher voltage.
Of course that will mean needing a bigger, better lipo too
