Help with ELDORADA
My Feedback: (12)
CA
Help with ELDORADA
Ok I'm new to RC's so bare with me..... I got the Himoto Eldorada for free from my cousin because he couldn't find the parts he needed to finish fixing the RC........... I found the sites and manual for the RC but I really can't tell what all is needed to get this RC up and running......
Here are a few pics of the Eldorada:
As far as I can tell I need these items:
06006 Transmission shaft 70MM*2PCS
02107 Clutch gear
02073 Servo unit
02070 Battery pack*1PC
06016 Servo link 2P
10234 1/10 truck body
02056 Throttle pull rod se
02017 Arms strengthen slice*2PCS
85754 Servo horn and throttle linkage set
02107 Clutch gear
02073 Servo unit
06016 Servo link 2P
CA
RE: Help with ELDORADA
i found a few other parts.. i added to your list....i also got the links for you..... hope this helps out..
06006 Transmission shaft 70MM*2PCS - http://server.sohouniverse.net/~himo...&=SID#MOREINFO
02107 Clutch gear - http://server.sohouniverse.net/~himo...&=SID#MOREINFO
02073 Servo unit - http://server.sohouniverse.net/~himo...&=SID#MOREINFO
02070 Battery pack*1PC - http://server.sohouniverse.net/~himo...&=SID#MOREINFO
06016 Servo link 2P - http://server.sohouniverse.net/~himo...&=SID#MOREINFO
10234 1/10 truck body - http://server.sohouniverse.net/~himo...&=SID#MOREINFO
02056 Throttle pull rod se - http://server.sohouniverse.net/~himo...&=SID#MOREINFO
02017 Arms strengthen slice*2PCS - http://server.sohouniverse.net/~himo...&=SID#MOREINFO
02028 Air filter W/ Sponge 1pc - http://server.sohouniverse.net/~himo...&=SID#MOREINFO
08016 Cam shaft*1 - http://server.sohouniverse.net/~himo...&=SID#MOREINFO
My Feedback: (12)
CA
Kuppler and Himotoracing thanks alot, I'll be ordering all the parts at the end of the week (gotta wait for payday ;-) lol )....... Hopefully I'll have this car up and running by next week...........
My Feedback: (12)
CA
LOL believe it or not hes the one that got me into RC's, and he actually gave me two for free.... The Himoto shown in first post and a Associated TC3, both needed parts to fix them but the cost to fix both cars is gonna run me less then 100 ;-) lol
I currently own after 3 weeks of starting out in RC's:
Himoto Eldorada
AE TC3
RC10GT with CF Chassis
RC10GT with Tube Chassis
Himoto Eldorada
AE TC3
My Feedback: (12)
CA
Oh sorry its the NTC3 so nitro...........
I'll probably be picking up an electric car from my co-workers husband.......... I'm just waiting to see what model it is and what scale...... It's gonna come with three bodies whole bunch of spare tires and parts all for 60 bucks lol, yeah I guess you can say I'm addicted..........
My Feedback: (12)
CA
Oh and another thin, would it be to much power to addthe SH.28 P3 engine into this RC???? Or would that be going overboard for what this truck can handle?
ORIGINAL: ilanstylz
CA
ORIGINAL: 7M
Theres no problem with adding too much power to the Eldorada (or Volcano in my case). Some may say it will strip the gars or fry up the gears but not through my experience. Ive been running a .21 8-port in my Volcano for a year, and and the gears held up fine (running a 52T direct drive tranny and 12T clutch bell). Lots of people are running big blocks in their Eldorada's with no problems, just make sure your gear mesh is spot on.
Nice.... can we get some video or pics of ur .21 8-port Volcano..??
ORIGINAL: 7M
ORIGINAL: ilanstylz
The Direct Drive Tranny (XXXXX edit: Syclone tranny) is much Less Likely to Strip than the STOCK tranny....
If you use the Stock tranny, then be careful about Grabbing a Fast Handful of throttle.
ESPECIALLY on Landing a Jump.....And make sure the Slipper clutch is properly adjusted......
Video Pleeeze....
the trans is from the syclone, 05126 and you would need a 13 tooth cluch bell to make up for the larger tires, cb13t.
The mamba/tsunami trans is way to high geared for the tires.
ORIGINAL: ilanstylz
i run a ntc3+, its a good track car with alot of adjustments for the suspension.
ORIGINAL: kuppler
ORIGINAL: 7M
my buddy rcdanny here on the forums put a hyper .21 in his eldorada and its insane. Only ploblem is that with the stock trans, it will rip up spur gears like crazy. I put a losi .26ss in my buddy mamba (basically the same as the eldorada) and its insane, totally insane. I have a video up on your tube with it. Its also running the 1/8 himoto tuned pipe too.
http://www.youtube.com/watch?v=YQy-7qEgr2k
ORIGINAL: HimotoRacingUSA
I keep up with Savages and T-Maxx's all the time. Im often called a poser cause I have a Redcat with Savage suspension, wheels and tires. [:@]
ORIGINAL: 7M
I Love It!....
Modding is what RC is All About,,,,,for Me anyway.....
Nice Job, 7m!!!
My Feedback: (12)
CA
NIIIIIICCCCCCEEEEEEEE RC's everyone, I'll take pictures of mine once I have all the parts necessary and up and running........... It probably be a few months before I upgrade the Himoto because right now im concentrating on my associated RC's............ But once I do start work on the Himoto I'm def. gonna upgrade the engine and lots more so I'll make sure to post pics and videos of before and after upgrades............
My Feedback: (12)
CA
Ok I finally got the parts in I ordered but I'm still missing a few pieces........ what size bearing do I need to put in the clutch bell that goes on the inside and outside???? Also for those who own the eldorada if you could take pictures of how you have the throttle servo hooked up to the tran and engine at different angles, that would help alot.......... sorry to say but the manuals I dl'd off himoto main site sucks...........
I have the throttle servo already I just need the top part which I believe is called the servo horn, does anyone have the exact part number of the one I need? And from 7M's picture I see he has a spring from the engine to the throttle servo, do I need one of those as well?
Does anyone have a better manual for the eldorada then the one given on their main site? Any and all help will be greatly appreciated, and as many pictures of your eldorada with no body will be a bigger plus... Thank You
I believe I need the servo throttle horn, the screws to mount the engine, the ball or flanged bearings for the clutch bell and eclip, the spring from the engine to servo, and the screw and nut that holds the front right steerin assembly should be all I need to complete the setup...........
That manual has an exploded view, you sould be able to get most of your parts off that but:
the throttle/brake setup(horn) includes the springs and arm: 02056
bearings for clutch bell(5x10x4): 02139
02096, 02093, 02083 screws should get you going.
