One way bearing troubles
NY
I am having some major trouble with the one way bearing in my Revo's transmission. It keeps slipping, and now it won't even grab at all. Is there any way I can clean it(just has to last to next Friday, payday) to get it going again? I just spent my weekly RC "allowance" on a backplate and starter shaft for the motor, one way bearing for the starter, a new body, and some fuel. I know the "right" way to fix it is to replace it, but I don't want to be down for another week after I've already been down for almost 2 weeks due to the motor backplate leaking around the starter shaft. Any help here would be of great appreciation. Thanks.
RE: One way bearing troubles
How cold is it there? Was your revo inside the house before you went out an tried to start it ?
I took my t-maxx to work 2 weeks ago, outside temp never got above 28 or so.
the t-maxx sat out in my truck all day, (pretty cold for around here) My friend brought his revo & rc10 gt, none of the 3 trucks
OWB would grab! after coming back home an lettin the truck sit inside a while the bearing grabbed every time!
I dont know if this is a common problem with cold temps or not but it seems like it to me.
NY
I keep it inside(in the shower if it has snow on it) my place, which hovers around 55 or so. I took it apart and cleaned the bearing with brake cleaner, and half the needles fell out. The little pins on the ends of most of the ones that fell out were gone. Guess I have no choice but to get a new on and have the truck down for ANOTHER week. Just my luck. Do a very moderate mod of the sleeve in the motor, and the increased power when I'm still at a rich tune is too much for the one way in the trans. Does anyone know where I can get just the bearing, it looks like it is pressed into the hub, which then uses an snap clip to hold it in the gear. I would like to find where to get the bearings by themselves because they are the exact same ones as the recoil uses, and it gets very frustrating to have to fork over 24 bucks every time a one way goes bad(this one will be around 30). Thanks.
NC
ORIGINAL: Straick
